The course participants can create and test programs from workpiece drawings with HEIDENHAIN conversational programming
  • Knowledge of milling according to a drawing, knowledge of the principles of CNC.
  • If you do not yet have the required fundamental knowledge, you can gain it either through a supplementary basic course or with the aid of a registration confirmation of the enclosed link “e-learning” (TNC Training).
Basic knowledge
  • File management
  • Tool table
  • Preset table
Path functions
  • Cartesian contour description
  • Polar contour description
 Cycles
  • Drilling cycles
  • Cycles for the milling of pockets, studs and slots
  • Face milling
  • SL cycles
  • Cycles for coordinate transformation
Programming technologies
  • Program section repeat
  • Subprogramming
  • Nesting
Pattern definitions, DXF converter and the simple contour formula
*Required Fields
