The purpose of this course is to provide both new and experienced operators with hands-on training using current controls as programming stations. The class covers basic programming structure, program management, basic functions of the contouring keys, and the use of pre-programmed canned cycles, as well as probing and setting datums. At the completion of this course the operator will be able to set up and run a 5-axis machine.
Basic Topics
- Data management, data transfer
- Datum management
- Tool management
- Path functions
- Linear Moves
- Circular Moves
- Machining cycles
- Cycles for drilling, pocket milling and stud milling
- Coordinate transformation
- Programming techniques
- Program section repeats
- Subprogramming
Advanced Topics
- Touch probe cycles
- Workpiece setting
- Workpiece alignment
- Automatic workpiece measurement
- Working in the tilted plane
- Nesting
- Programming with variables
- Parameter programming
- Program jumps
- Reading/writing of system parameters
- 5 axis accuracy: KinematicsOpt
