The purpose of this course is to provide both new and experienced operators with hands-on training using current controls as programming stations. The class covers basic programming structure, program management, basic functions of the contouring keys, and the use of pre-programmed canned cycles, as well as probing and setting datums. At the completion of this course the operator will be able to set up and run a 5-axis machine.
Basic Topics
- Data management, data transfer
 - Datum management
 - Tool management
 - Path functions
- Linear Moves
 - Circular Moves
 - Machining cycles
- Cycles for drilling, pocket milling and stud milling
 - Coordinate transformation
 - Programming techniques
- Program section repeats
 - Subprogramming
Advanced Topics
- Touch probe cycles
- Workpiece setting
 - Workpiece alignment
 - Automatic workpiece measurement
 - Working in the tilted plane
- Nesting
 - Programming with variables
- Parameter programming
 - Program jumps
 - Reading/writing of system parameters
 - 5 axis accuracy: KinematicsOpt
