The participants can:
- Create cycle-type machining sequences
- Programming milling operations of plane curves with mathematical functions
- Combination of Q parameters and HEIDENHAIN cycles
- Use the functions FN 16; 17; 18;…
Experienced programmers and operators of CNC milling machines, CNC trainers, application engineers
- Completion of the basic course, or the equivalent knowledge of programming with the control.
- Understanding of logical operations (If… then…)
Reading and writing of machining cycles
- Programming techniques
- Logical operations (If….then)
- Conditional and unconditional jumps
- Branching in programs and outside of the program
- Program section repeats
- Nesting techniques
Drilling
- Simple bolt hole circle
- Universal deep-hole drilling cycle
Milling in the plane
- Milling cycles for contours and technical curves (e.g. ellipses, spirals)
- Letter engraving program
Milling of bodies
- Schemata for repeatable 3-D task types
- Milling cycles for spatial machining (tapered internal threads, Archimedean spirals, etc.)
- Combination of HEIDENHAIN cycles with Q parameters
- Rounding of corners on any contours
Miscellaneous functions
- Logging of data with the aid of freely definable tables
- Practical applications for the functions FN 16; 17;18; …
