- Distinguish between the different NC program types
- Use the TCPM function
- Take advantage of possibilities for optimizing the control
- Completion of the basic course, or the equivalent knowledge
- Fundamentals of tilted machining
- Process chain fundamentals
- Difference between tilting 3+2, inclining and simultaneous machining
- Output format of NC programs
- Capabilities of M128 and TCPM functions
- 3-D tool radius compensation
- Optimizing and structuring NC programs
- Using KinematicsOPT
- Global program settings
- Tips for postprocessor configuration
- Packet of functions for roughing and finishing
