Programming techniques
  • Subprogramming
  • Program section repeat
  • Calling an independent program as a subprogram
  • Nesting
 Using cycles
  • For drilling, tapping and thread milling
  • Milling pockets, studs and slots
  • Contour milling with SL cycles
  • Cycles for coordinate transformation
  • Special cycles
 Machining geometric shapes
  • Milling operatioon with end mill in several passes
  • Combining coordinate transformations for milling operations
  • Rotationally symmetric spatial machining
  • Miscellaneous functions for contouring behavior
Q parameter programming
  • Principle and overview
  • Basic functions
  • If/Then decisions with Q parameters (jumps)
iTNC 530
  • Preset table
  • Plane functions
  • Simple contour formula
  • Programming aids
 FK programming, DXF converter and tool monitoring
The course participants expand and deepen their knowledge of the individual topics on HEIDENHAIN conversational programming
Completion of the Basic Training or the equivalent knowledge of programming with the TNC control
After submitting your registration, contact Sandy Gilmore at (847) 490-7822 with your credit card information to make payment. Registration is considered confirmed only after your payment has been received.
Questions can be directed to Sandy: sgilmore@heidenhain.com.
*Required Fields
