The course participants can create and test programs from workpiece drawings with HEIDENHAIN conversational programming
- Knowledge of milling according to a drawing, knowledge of the principles of CNC.
- If you do not yet have the required fundamental knowledge, you can gain it either through a supplementary basic course or with the aid of a registration confirmation of the enclosed link “e-learning” (TNC Training).
Basic knowledge
- File management
- Tool table
- Preset table
Path functions
- Cartesian contour description
- Polar contour description
Cycles
- Drilling cycles
- Cycles for the milling of pockets, studs and slots
- Face milling
- SL cycles
- Cycles for coordinate transformation
Programming technologies
- Program section repeat
- Subprogramming
- Nesting
Pattern definitions, DXF converter and the simple contour formula
