- Apply the function for tilting the working plane for swivel heads
or tilting tables - Work with rotary axes and spatial angles
- Distinguish between the different NC program types of the TNC
- Distinguish between the different TCPM functions (inclined and simultaneous machining) and use them
- Use functions to influence the program execution behavior of the control or to adjust NC programs
Programmers and operators of CNC milling machines, CNC trainers, CAM users / programmers
- Knowledge of CNC fundamentals
- Completion of the basic course, or the equivalent knowledge of programming and operating the control
- Common tilting designs
- Presetting and probing in the tilted or non-tilted coordinate system
- Manual tilting
- Guideline for program run
- Tilting the working plane, preferably using the PLANE-functions
- Use of the preset table
- Datum shift from programs or tables
- Execution of various cycles and contours in tilted condition
- Machining with several tools
- Resetting the tilt
- Changing the tool penetration angle via M114, M128 and TCPM
- Use and combination of further tilt-specific M functions
- Basic information about 5-axis machining
- Output formats of NC programs: plain-language messages, vector output
- 3-D tool radius compensation
- Optimization of NC programs: Cycle 32, Cycle 332, M124, M120
- Using KinematicsOPT
