New Absolute Linear Encoders For Tight Spaces
December 12, 2017
NUMERIK JENA, known for high quality smaller package-size linear and rotary encoders, has now developed two families of absolute linear encoders to fit into tight spaces. Called the LAK and KIT LA, these non-contact encoders offer several types of electrical interfaces, including EnDat 2.2 with analog signals, a key market request. This interface allows motion stage manufacturers to use the absolute position values and the analog position values for different purposes.
Available in North America through HEIDENHAIN CORPORATION, these NUMERIK JENA absolute linear encoders can serve many precision measurement feedback applications in the semiconductor, medical, automation and metrology industries.
The new LAK scanning units have a shielded housing whereas the KIT LA scanning units are a sensor with an optional frame, both of which have two scanning fields for superior contamination resistance. The Endat 2.2 versions are capable of resolving down to 10 nanometers resolution at a velocity of 10 meters per second. Other available interfaces include BISS C, SSI, and a HIPERFACE-compatible option.
The steel scale substrate in the encoders comes in the industry- accepted Singleflex or Doubleflex mounting options at up to a measuring length of 1.2 meters. On each scale, there are two Periodic Random Code (PRC) tracks that are inverted with respect to each other and are arranged in parallel to a centered incremental track with a 20-micron grating period. The two PRC tracks allow the scanning unit to measure the yaw angle, which is helpful for some processes. The scales are sold at an accuracy class of +/- 3microns per meter.
The encoder systems are installed via USB with the Absoflex diagnosis software.
Precise Satellite Positioning to the Nearest Micron
Electronic components in a new hyperspectral satellite are mounted in an exceedingly compact space using HEIDENHAIN LIP 581 linear encoders and POSITIP 880 digital readout.
How Semiconductor Producers are Keeping Up
Historically, few components, of any kind, require the level of production precision of semiconductor components. Considering the increasing variation in mobility and environmental influences on their performance and physical obsolescence—think artificial intelligence, autonomous vehicles, the internet of things, 5G communications, the list goes on—limits are being pushed even further. Add the fact that application and […]
New High-Resolution Modular Angle Encoders
The ERP 1000 encoders with exceptionally high resolution, high speed, and high contamination resistance, useful for highly-accurate measurement/positioning.
