New Leine & Linde Linear Encoder for Toughest Environments
August 13, 2018
linear encoderSchaumburg, IL (August 2018) – Leine & Linde has been a well-known supplier of solutions for velocity feedback and position feedback in heavy-duty industrial processes for several years. Now, for the first time, Leine & Linde will be releasing a robust linear absolute encoder series, the RLA 4000, to meet the needs of tough environments, particularly of use as part of roll gap regulation in the steel industry.
As many know, a steel mill’s rolling stands operate in one of the industry’s absolute toughest environments, with high temperatures, aggressive chemicals, shock impact and vibrations. Nevertheless, thanks to its heavy-duty construction, the new Leine & Linde RLA 4000 linear encoder series can stand up against the demanding environmental conditions inherent in this application.
These new linear encoders come with an encapsulation that enable them to withstand heat and other strong external stresses, while their absolute inductive scanning resists the hard impact and strong vibrations. Due to this unique design and capability, the new RLA 4000 series from Leine & Linde does not need to be installed inside a cylinder, unlike other encoder solutions for roll gap regulation. This makes the encoders much more accessible for installation and service.
Additionally, the RLA 4000 series provides absolute position values directly to the PLC, meaning no additional counter is required as a go-between, and the encoder cannot lose track of its position, even though a power cycle. The linear sensor in the 4000 series comes with measurement lengths up to 260 mm and output interfaces of SSI or EnDat. Using the robust gateway solutions from Leine & Linde, PROFINET, PROFIBUS and EtherNet/IP interfaces are also available as options.
More information is available from North American Product Specialist Jonathan Dougherty at 847-519-4218.
See Motion Control Components at Automate 2019
From April 8-11, visit HEIDENHAIN’s Automate 2019 booth (#8346) at Chicago’s McCormick Place, showcasing multiple motion control component brands.
New LC 201 Single-Section Linear Encoder
The new LC 201 absolute linear scale is a single-section METALLUR tape encoder, ideal for use in linear motor applications.
New ND 7013 DRO offers improved interface, touch screen
The new ND 7013 DRO offers an improved user interface and user-friendly touch screen to better utilize manually-operated machine tools with up to 4 axes.
