Leine & Linde’s Premium Rotary Encoders for Harsh Environments Now Available with PROFINET
February 29, 2016
Particularly useful in the automation systems of heavy equipment
The inductive scanning principle used within the Leine & Linde 900 series is known for enduring conditions like high temperatures, moisture, vibration and shock, without compromising on resolution and accuracy. The new PROFINET interface expands upon the existing EnDat, PROFIBUS, EtherNet/IP™, EtherCAT and DRIVE-CLiQ interfaces, and allows integration with a wide range of automation systems.
The 900 series supports a variety of mechanical interfaces as well, including taper and keyed shafts, a hollow shaft with keyway, and incorporates bearings twice the size of similar encoders on the market.
The 900 series PROFINET is also available with dual output for achieving both absolute and incremental signals, supporting a wide range of control system interfaces.
For more information on these encoders, contact Bob Setbacken at HEIDENHAIN at 805-562-1160, or e-mail at bsetbacken@heidenhain.com, or write to HEIDENHAIN CORPORATION, 333 E. State Parkway, Schaumburg, IL 60173.
