Leine & Linde Offers Unique Component for Machine Speed Safety Applications
March 20, 2015
Compact Robust Gateway (CRG) Overspeed
Schaumburg, IL (March 2015) – Leine & Linde now has available a Compact Robust Gateway (CRG) Overspeed,  a unique combined overspeed and signal monitoring component intended for use in motion control applications where safe speed feedback is required.
Coupled with an encoder, the CRG Overspeed component can be used to independently monitor whether machine’s speed is within allowable limits. For example, when a crane lifts or lowers a load, the motion will be driven by a motor and an incremental encoder is used to monitor the speed to ensure that it stays within safe levels. Leine & Linde’s CRG Overspeed is pre-programmed to independently compare encoder output signals to a specified speed which is specific to the application. If the encoder outputs reach the speed limit, the gateway will output an alarm on a set of redundant relays to alert the control system.
In safety critical applications, it is also important to know that the encoder outputs are valid. The CRG Overspeed also features advanced logic to verify proper operation by continuously monitoring the encoder output signal transitions and voltage levels. A separate output relay is provided for assertion of this alarm condition.
The CRG Gateway will also integrate diagnostic outputs from Leine & Linde encoders with the Advanced Diagnostic System (ADS). This feature allows combination of overspeed conditions, output signal errors, and internal encoder diagnostics into one alarm signal to the control system.
For more information on these encoders, contact Bob Setbacken at HEIDENHAIN at 805-562-1160, or write to HEIDENHAIN Corporation, 333 E. State Parkway, Schaumburg, IL  60173.
Leine & Linde is based in Sweden with exclusive North American distribution through HEIDENHAIN Corporation in Schaumburg, IL. Leine & Linde is well known for offering high quality, heavy duty encoders of both the incremental and absolute type, are noted for their product robustness and design to cope with the harshest of environments, such as those with high vibration, dirt and cold temperatures. These heavy, severe duty encoders are suited for drive and measurement applications and are often found in industries such as pulp and paper, forest and wood processing, agriculture, aggregate and mining equipment.
