Leine & Linde Adds Speed Monitoring to Encoder
July 25, 2016
Kathleen Stoneski, PR Manager, 847-519-4702
SCHAUMBURG, IL (July 2016) – The Leine & Linde 1000 series rotary encoder with speed monitoring capabilities is used in applications where secure speed feedback is critical in order to protect motors, machinery or operators from risk of failure. This is especially useful on heavy moving machinery such as hoists, lifts, cranes and mining equipment, to name a few.
Leine & Linde’s overspeed electronics on the 1000 series consist of a speed detection system that senses rotational speed and direction. These electronics control three different relay switches which can be programmed for identification of critical speeds or errors in direction. In addition, a fourth relay can be set to detect overspeed conditions, or be set to detect any functional error in the unit itself.
As critical speeds can vary for different applications, the ability to program application specific set-points offers considerable flexibility. With this capability, a standard 1000 series encoder with overspeed electronics can be supplied and programmed for each installation. Speed limits can be set for direction, over and under speed from 0 to 6000 rpm. PC-based software is provided to configure the encoder using a standard USB port.
The Leine & Linde 1000 is designed to meet exceptional requirements in real-world heavy duty applications. With sturdy bearings and enclosure, the 1000 series encoders achieve extraordinary durability towards mechanical stress. The encoder is rated at 200g shock, 30g vibration, and its IP67 enclosure can also withstand wet or dusty environments with high temperatures.
For more information on these encoders, contact Bob Setbacken at HEIDENHAIN at 805-562-1160 or write to HEIDENHAIN Corporation, 333 E. State Parkway, Schaumburg, IL 60173.
Leine & Linde is based in Sweden with exclusive North American distribution through HEIDENHAIN Corporation in Schaumburg, IL. Leine & Linde is well known for offering high quality, heavy duty encoders of both the incremental and absolute type, are noted for their product robustness and design to cope with the harshest of environments, such as those with high vibration, dirt and cold temperatures. These heavy, severe duty encoders are suited for drive and measurement applications and are often found in industries such as pulp and paper, forest and wood processing, agriculture, aggregate and mining equipment.
