New Angle Encoder Modules for High System Accuracy
September 1, 2016
High System Accuracy and Built to Take LoadINFO mini header-circle
HEIDENHAIN launches a new product family that is a merger of HEIDENHAIN bearing and angle encoder technologies. Resulting in the MRP 2000, 5000 and 8000 (as well as customer-specific variants), these unique modules contain bearing sets not conventionally available and are able to be integrated with various encoder types to yield highly stiff modules that are easy to install. These angle encoder modules represent a successful merging of the key requirements for precision rotary axes used in metrology, calibration devices, automation technology, micro machining, and the semiconductor industry.
Key features
  • A remarkably high guideway accuracy combined with high rigidity.
  • A low starting torque and a constant continuous torque.
  • At the same time, value was placed on compact dimensions due to the fact that the bearing raceway is machined directly onto the shaft.
  • Bearing loads up to 300 Newtons are possible while still maintaining the system accuracy.
The encoders fulfill the high requirements for any motion feedback application. Their most important features are high resolutions, excellent signal quality and best repeatability, even when operating temperatures vary. Incremental or absolute encoders can be used as required, with resolutions up to 29 bits. The encoders also ensure low position noise and low position drift.
Each encoder module undergoes an extensive accuracy test involving a unique five-dimensional test for wobble as well as axial and radial guideway accuracies. Therefore, two Quality Inspection Certificates are enclosed with each module. The first certificate documents the system accuracy and the second one documents the guideway accuracy.
How to choose the right encoders for semiconductor machinery
You can have all the bandwidth, AI, or optics in the world, but none of it matters if a semiconductor tool cannot meaningfully reach nanometer level precision without compromising its throughput. When the goal is to make precise measurements as quickly as possible, the max speed of a motion system’s axis won’t matter if it’s […]
Controlling Motion in 9 Challenging Environments
When it comes to choosing motion control equipment, there are countless variables to consider. The type of motion and speed are good first steps, but the environment will almost always need to be factored in too.  Uncommon settings, like high radiation, extreme temperatures and explosive environments, just to name a few, provide their own set […]
How interface electronics are enabling Industry 4.0
Just like encoders and motors have had to advance to meet the demands for higher throughput and smaller products, so have the interfaces they use to communicate. Automating production ultimately depends on the fast and accurate transfer of data. And the intensely competitive race to digitize and gather actionable data has put added emphasis on […]
