HEIDENHAIN’s Popular Mill-Turn Control Adds Powerful New Features
June 20, 2016
INFO mini header-circleThe TNC 640, HEIDENHAIN’s high performance mill-turn control, has added powerful new cycles and features. Enhanced graphics, interpolation turning and gear hobbing are some examples that will extend the versatility of the TNC 640 to new applications such as for machining large parts for power plants. Additionally, new manual probing cycles will make it easier for the operator to setup workpieces.
The TNC 640’s new graphics package includes a CAD viewer that opens any *.Step, *.Iges and *.Dxf file, and allows an operator to evaluate the workpiece at the control. For the machine builder, DCM (Dynamic Collision Monitoring) is available on the TNC. For this, HEIDENHAIN created a M3D converter. Through this powerful PC tool, CAD files of components in the machining envelope can be merged, edited and added to the Collision Monitoring.
And when the new interpolation turning feature is in use with a TNC 640, the associated machine tool’s linear axes move along a circle, while the cutting edge with the milling spindle is always oriented to the center of rotation (outside machining) or away from the center of rotation (inside machining). Interpolation turning is especially well suited for manufacturing large, rotationally-symmetric sealing surfaces and, for example, for machining the housings of components of power plant technology (energy generation).
Another new feature is Cycle 880, for gear hobbing of external cylindrical and helical teeth. This machining process is performed through synchronization of the tool and lathe spindles. Furthermore, the cycle positions the rotary axis to the required tilting position and performs the infeed movements to the workpiece in the radial direction, and the milling movements in the axial direction.
This machining process is for external cylindrical and helical teeth, and is performed through synchronization of the tool and lathe spindles.
Lastly, determining the 3-D basic rotation for a plane surface has been added as a manual probing function. The misalignment of a surface can be measured by probing three points in any direction on that plane. Subsequently, the result can be transferred to the datum table and/or the workpiece can be aligned.
Tamsen Maritim shipyard: fit & ready
Factory hall = Work envelope. This simple equation is probably the best way to describe the huge 5-axis portal milling machine at the Tamsen Maritim shipyard.
2021 Training Calendar: HEIDENHAIN & ACU-RITE
Click 2021 Training Calendar image to open interactive PDF Technical qualification and continuing training are indispensable for achieving technological improvement and securing the future of a company and its employees. HEIDENHAIN CORPORATION and ACU-RITE in Schaumburg, IL, provide technical training covering installation and programming as well as general training for distributors and end-users. Included on […]
