HEIDENHAIN’s New TNC 640 Control – Introduced for Milling and Turning Machines
August 24, 2012
Kathleen Stoneski, HEIDENHAIN PR Manager, North America 847-519-4702
TNC640SCHAUMBURG, IL (August 2012) –
Poised to be unveiled to North America during the upcoming IMTS trade show is the TNC 640, HEIDENHAIN’s first milling-machine control offered with optional turning functions.  With this control, HEIDENHAIN is expanding its already versatile selection of high performance controls into the MILL-TURN market.
With the TNC 640 control, turning operations can now be enabled on a milling machine allowing the operator to transition from Milling to Turning cycles in the same program.  The turning operations can be programmed in plain text, just like the familiar milling operations.  Comprehensive turning cycles are available for frequently repeated operations, such as roughing, finishing recessing and thread cutting.
The TNC 640 is based on HSCI (HEIDENHAIN Serial Controller Interface), the new and completely digital interface hardware platform.  This significantly reduces cabling during setup.  The new ergonomic design of the 19″ screen, the operating panel with stainless steel fronts and the modern function and status displays provide the TNC 640 with an optimized user-friendly appearance.  The new smartSelect function makes it easier, for example, to select cycles, and syntax color highlighting improves clarity for the editing of machining programs.
The TNC 640 also introduces a new stainless steel control design and a specially prepared keyboard surface and screen frame to eliminate fingerprints.
New ETEL Motion Platform Wins LEAP Award
SCHAUMBURG, IL (December 2019) – The ground-breaking new ETEL TELICA motion platform designed for semiconductor manufacturing was the recipient of the LEAP award at a ceremony in Santa Clara, CA, on December 9. Presented with the Silver LEAP (Leadership in Engineering Achievement Program) in the category of Motion Control, representatives of ETEL of the HEIDENHAIN […]
Klartext Portal: TNC online user support
The Internet is an endless source of knowledge. Knowing where to look for the information you need can seem like a daunting task. For TNC control users, the Klartext Portal is the place to go. The Klartext Portal is the go-to site for user support related to HEIDENHAIN controls. To keep you from getting lost […]
2020 Training Calendar Released
Click image to open interactive PDF Technical qualification and continuing training are indispensable for achieving technological improvement and securing the future of a company and its employees. HEIDENHAIN CORPORATION in Schaumburg, IL, provides technical training covering installation, programming and PLC programming as well as general training for distributors and end-users. Classes include engaging presentations and […]
