HEIDENHAIN to Unveil New Hollow-Shaft Rotary Encoders at Upcoming SPS IPC Drives Show
November 9, 2016
Jonathan Dougherty, Product Specialist, 847-519-4218
Kathleen Stoneski, Public Relations Manager, 847-519-4702
SCHAUMBURG, IL (November 2016) – For the SPS IPC Drives 2016 trade show, HEIDENHAIN is supplementing its existing program of inductive position encoders with its new rotary encoder series ECI 4000/EBI 4000. To be shown at the show in Nuremburg, Germany on November 22-24, the new encoder variants are modular devices without integral bearing and with a 90 mm hollow shaft. This enables the user to replace the conventional toothed-belt drive for coupling a motor feedback system to torque motors.
With fewer components, these new rotary encoders provide increased performance and guaranteed wear-free operation. Moreover, they set new standards in attainable control dynamics, reliability and functionality. In this way, they open up new applications for inductive rotary encoders, e.g. on highly dynamic motors, drive modules and machine components that require a corresponding hollow shaft in the encoder.
The singleturn version of the ECI 4000 features resolution of 20 bits. As an alternative, with its EBI 4000, HEIDENHAIN offers a multiturn variant that features a revolution counter option with resolution of 16 bits and that is backed up by an external battery buffer. The new inductive rotary encoders consist of a scanning unit and the scale drum. With an overall height of only 20 mm, they have outstanding characteristics.
The scanning is performed through an all-round scanning. In this setup, the complete graduation structure of the scale drum (rotor) with the associated scanning band of the scanning unit (stator) is involved in obtaining the position signal. In this way, the rotary encoder evaluates two incremental scanning tracks of differing periodicity. This scanning principle has an extremely positive effect on the mounting tolerances and the positioning accuracy. Additionally, over the entire velocity range up to 6000 rpm, it largely compensates position error arising from a rotational center offset of the measured shaft.
The new inductive rotary encoders ECI 4000 and EBI 4000 are equipped with the digital EnDat 2.2 interface. In addition to noise-free transmission, the EnDat 2.2 interface also supports further encoder-specific functions, such as the data transfer from one temperature sensor inside the encoder and one outside of it, or the allocation of standardized valuation numbers for signal diagnostics. The output of these operating parameters in the closed control loop allows permanent monitoring of the encoder status. Additional connections are possible with the DRIVE-CLiQ* interface available as an option for the singleturn version.
Certification for SIL 2 applications in compliance with EN 61508 is being planned for the encoders. By employing additional measures in the subsequent electronics, users can raise the security level of the EnDat 2.2 devices to SIL 3. The relevant fault exclusion criteria for a safe mechanical connection are of course part of the certification.
The encoders are designed for easy installation and the ability to smoothly integrate into the applications of motors and machines. Among other things, they fulfill protection class of IP40 for this. Thanks to an external and an internal centering diameter on the scanning unit and scale drum respectively, they can be mounted quickly without any special tools for adjusting and testing and immediately put into operation. An application-specific axial offset of the scale drum to the scanning unit is tolerated in a range of ±1.5 mm. The maximum drive shaft runout tolerance is similarly generous at 0.2 mm.
The operating temperature range for encoders with EnDat 2.2 interface is up to +115 °C. Vibration resistance is 400 m/s² for the stator and 600 m/s² for the rotor in accordance with EN 60068-2-6. This guarantees great robustness as a motor feedback system—particularly when the motor is designed for high performance.
Prototypes for this product are available now and can also be seen at our booth:
HEIDENHAIN at SPS IPC Drives: Hall 7, Booth 7-190
HEIDENHAIN CORPORATION is the North American subsidiary of DR. JOHANNES HEIDENHAIN GmbH, a leading international manufacturer of precision measurement and control equipment. Our product line includes linear scales, rotary and angular encoders, digital readouts, digital length gauges, CNC controls, and machine inspection equipment.
*DRIVE-CLiQ is a registered trademark of SIEMENS AG.
New ETEL Motion Platform Wins LEAP Award
SCHAUMBURG, IL (December 2019) – The ground-breaking new ETEL TELICA motion platform designed for semiconductor manufacturing was the recipient of the LEAP award at a ceremony in Santa Clara, CA, on December 9. Presented with the Silver LEAP (Leadership in Engineering Achievement Program) in the category of Motion Control, representatives of ETEL of the HEIDENHAIN […]
2020 Training Calendar Released
Click image to open interactive PDF Technical qualification and continuing training are indispensable for achieving technological improvement and securing the future of a company and its employees. HEIDENHAIN CORPORATION in Schaumburg, IL, provides technical training covering installation, programming and PLC programming as well as general training for distributors and end-users. Classes include engaging presentations and […]
New North American Service Partners
Over the past year, five new HEIDENHAIN Service Partners have been established in various U.S. regions to assist in reducing wait times and costs for in-field service calls. As part of HEIDENHAIN’s ongoing “Customer First” initiative, these new North American Service Partners are providing stronger local connections for HEIDENHAIN customers, and ultimately reducing downtime and […]
