May 28, 2026
Common manufacturing challenges are reshaping motion technology
Modern manufacturing systems are being asked to do more than ever before. Machines are expected to move faster while maintaining tighter tolerances. Production environments are becoming increasingly connected. Skilled labor shortages continue affecting operations across industries. At the same time, manufacturers are under constant pressure to improve uptime, efficiency, and long-term reliability.
These challenges are not isolated to one industry or application. They affect everything from precision machining and robotics to heavy-duty automation, semiconductor manufacturing, and advanced motion systems. As manufacturing evolves, the technologies supporting it must evolve as well.
Across HEIDENHAIN and the HEIDENHAIN Corporate Group, this has led to a broader focus on high accuracy measurement, advanced diagnostic capability, and faster feedback communication designed to help manufacturers address some of the industry’s most common operational challenges.
When precision becomes the standard
Accuracy has always mattered in manufacturing, and today, it has become foundational. Modern automation systems, advanced machine tools, robotics platforms, and positioning applications increasingly rely on exact motion control and dependable feedback to maintain process quality. Small positioning deviations can directly affect surface finish, repeatability, throughput, and system reliability.
This growing demand for precision extends beyond a single product category. HEIDENHAIN linear encoders help eliminate mechanical error sources such as backlash and pitch inaccuracies for highly accurate axis positioning. Angle encoders support precise rotary positioning down to a few arc seconds, while rotary encoders provide dependable speed and position feedback across a wide range of industrial applications.
Across the HEIDENHAIN Corporate Group, specialized technologies further support demanding positioning tasks. AMO contributes robust inductive encoder technologies designed for challenging environments. NUMERIK JENA provides compact, highly accurate optical measurement solutions for applications with strict space and precision requirements. RSF supports high-accuracy linear motion systems used in advanced automation and metrology applications.
Together, these technologies help manufacturers maintain the positioning accuracy modern systems increasingly require.
Downtime is more than lost production
Unplanned downtime affects more than machine availability. It disrupts schedules, delays deliveries, increases maintenance pressure, and creates operational uncertainty across the entire production environment.
As systems become more connected, manufacturers are placing greater focus on condition monitoring, diagnostics, and predictive insight.
This shift is changing the role of measurement technology itself.
Encoders are no longer limited to position feedback alone. Technologies such as the ECI 1323 Splus and EQI 1335 Splus integrate vibration analysis directly into the encoder through embedded accelerometers and onboard processing capability. Combined with EnDat 3, these systems can communicate both motion feedback and diagnostic information through a single interface.
For heavy-duty applications, Leine Linde technologies extend this concept further through their Advanced Diagnostic Solution, ADS Uptime, which helps operators monitor long-term system health, track operating conditions, and identify developing issues before failures occur.
Within machining environments, TNC7 also supports improved process visibility through integrated workflows, process monitoring capabilities, advanced visualization, and machine support tools designed to help operators work more efficiently while maintaining greater control over production processes.
The goal is no longer simply reacting to downtime after it occurs. Increasingly, manufacturers are working to prevent it before it begins.
The industry’s skills gap continues to grow
One of manufacturing’s most discussed challenges is also one of its most difficult to solve: experienced labor continues becoming harder to find.
As machining, automation, and manufacturing systems become more advanced, the need for effective training and operator support continues growing alongside them.
This challenge extends beyond programming alone. Operators today are expected to manage increasingly connected systems, complex machining strategies, advanced controls, and integrated production workflows. Technology can help simplify that transition when designed around usability as well as capability.
The newest CNC control from HEIDENHAIN, the TNC7, reflects this shift with a more modern and task-focused control experience that supports conversational programming, dynamic graphics, customizable workflows, integrated process support, and advanced machining functionality within a more intuitive environment.
At the same time, HEIDENHAIN training programs continue helping manufacturers, operators, and programmers strengthen their understanding of modern machining technologies through instructor-led courses, advanced applications training, and practical hands-on learning environments.
As manufacturing evolves, supporting the people operating the technology becomes just as important as advancing the technology itself.
Manufacturing conditions are not always ideal
Modern systems are expected to perform reliably in environments that are often difficult, unpredictable, or physically demanding. Heat, vibration, contamination, humidity, shock loads, and electrical interference continue challenging motion systems across industries such as marine, steel, automation, heavy equipment, and energy production.
In these applications, reliability becomes critical.
Leine Linde encoder technologies are designed specifically for demanding industrial environments where uptime and dependable feedback are essential. Inductive scanning technologies, rugged mechanical construction, advanced diagnostics, and long operating life help support reliable performance under challenging operating conditions.
Similarly, technologies such as TRUE IMAGE from HEIDENHAIN help maintain dependable encoder operation under contamination and condensation conditions, reducing dependence on purge air systems in certain applications.
These technologies reflect a larger reality across manufacturing: performance alone is no longer enough without long-term reliability behind it.
Automation is expanding the role of measurement
Automation systems continue becoming more dynamic, connected, and intelligent.
Robotics systems must adapt to changing loads in real time. Motors require increasingly advanced diagnostic capability. Connected manufacturing environments rely on continuous communication between machines, controls, sensors, and feedback systems.
As these systems evolve, measurement technology is becoming more deeply integrated into how automation itself operates.
Technologies such as the KCI 120 Dplus support highly accurate robotic positioning through dual-position measurement capability. EnDat 3 enables advanced communication structures, hybrid cabling, functional safety, and expanded sensor integration for connected manufacturing environments. Encoder technologies across the HEIDENHAIN Corporate Group support robotics, motors, automation systems, and advanced positioning applications requiring both precision and system intelligence.
In modern automation, understanding motion is becoming just as important as generating it.
Supporting manufacturing through every stage of change
Manufacturing continues changing rapidly, but many of the industry’s core challenges remain consistent: improving accuracy, reducing downtime, supporting operators, increasing reliability, and adapting to more connected production environments.
Across HEIDENHAIN and the HEIDENHAIN Corporate Group, technologies for measurement, motion feedback, controls, diagnostics, and automation are designed to help manufacturers navigate those challenges with greater confidence.
Because increasingly, manufacturing success depends not only on how systems move, but on how well that motion is measured, monitored, controlled, and supported.
