Check Out HEIDENHAIN’s Versatile High Accuracy Length Gauge
January 4, 2014
HEIDENHAIN is thrilled to now offer the ACANTO 30xx, the newest product in HEIDENHAIN’s line of high accuracy length gauges. The ACANTO 30xx features a 30 mm measuring stroke, ideal for measuring objects of multiple sizes or for applications that require a long travel.
The ACANTO features an EnDat 2.2 serial interface, which outputs absolute position data. Upon power up, the ACANTO will know exactly where it is without needing to cross reference marks. Datum information will also be stored with the gauge. In addition, when used in combination with HEIDENHAIN’s GAGE CHEK digital readout, ND287 digital readout, or MSE 1000 multiplexor, diagnostic information of the ACANTO can be checked. The online diagnostics ensure that the operator is always informed about the current condition of the length gauge.
The ACANTO features a detachable cable for easy installation, and servicing and comes in two variants, manual or pneumatic. Both variants have an accuracy grade of ± 2 µm and a resolution of 368 nm. In order to satisfy the harsh environmental demands for in-process measurements, the ACANTO 30xx has IP 67 protection allowing it to even temporarily be immersed in water. The plunger is held by a sturdy ceramic/polymer friction bearing making the ACANTO less sensitive to excessive clamping and side loading. The ACANTO has a life cycle of 5 million load cycles and is perfect for automated industrial measurements.
ETEL Adds EtherCat to AccurET Controls
Schaumburg, IL (August 2019) – Available in North America from HEIDENHAIN CORPORATION is a new version of the ETEL-brand AccurET controls with EtherCAT compatibility. As EtherCAT communication moves from “mid-end” automation to more high-end machine control applications, demand for this has been increasing. With that in mind, ETEL now allows its product users to take […]
SCHAUMBURG, IL (August 2019) – In a collaborative effort to best enable 5-axis machining for users with HEIDENHAIN TNC controls and Mastercam® CAD/CAM software, a new collaborate post processor is now available. Called the HEIDENHAIN TNC 5X Mill post processor, CNC Software, Inc., developers of Mastercam software, introduced it recently after coordinating development efforts between […]
Leine Linde Sensor Better Measures Equipment Strain
Schaumburg, IL (July 2019) – Leine Linde’s new ESR digital strain sensor is now available to monitor structural health on equipment where needed. Offered in North America through HEIDENHAIN CORPORATION, it is coupled with an encoder using the digital interface EnDat, and offers significantly higher signal quality, accuracy and robustness when compared with conventional strain […]
