Gen. 3 Inductive Encoders with Functional Safety
January 28, 2015
HEIDENHAIN’s new generations of absolute inductive rotary encoders with functional safety are now available. The Generation 3 ExI 1100 and 1300 series encoders provide a single encoder safety solution for many industries such as packaging, automation and robotics.  These new products are especially suitable for safety-related applications up to SIL 3, PLe, and Category 4 or any application involving high risks for the operator, such as when they are required to interact with a robot directly.
The ExI 1100 encoders are 35 mm sized encoders while the ExI 1300 series feature a larger 56 mm hub size.  Both these series encoders are implemented with a HYDRA III scanning ASIC and also offer a host of different safety-related functions that can be upgraded even further with the implementation of safe control that supports the EnDat Safety Master.  These additional measures can be implemented independently of the control loop parameter. This allows the safety measures available to work directly with a controls safety module, without being affected by changes in control-loop parameters
The ECI 1×19 and EQI 1×31 each feature an increased single turn resolution of 19 bits while the EQI 1×31 can track 4096 (12 bits) revolutions. These next gen. encoders showcase improved vibration specifications (400 m/s2 stator and 600 m/s2 rotor), as well as a more durable multi-turn gearbox, and an increased permissible axial motion of the shaft up to ± 0.4 mm. They also have the advantages of previous bearingless, inductive encoders which include the non-contact design, resistance to contamination, no mechanical self-heating, and reduced sensitivity to radial runout.
How to Select A Servo Motor
Updated on: 12/20/2019 Servo motors are a type of electric motor (rotary actuator) that allows for precise control of position, velocity and acceleration. They employ a closed-loop system, meaning there’s a feedback device (like an encoder) that communicates with a control such as a CNC machine control. Magnetism controlled by electricity is used to drive […]
4 Popular Servo Motor Applications
Servo motors are relied on far and wide for controlled linear or angular motion. They are deployed in systems we interact with every day as well as more specialized mechanical systems. Typically working with a positional feedback device, such as an encoder or resolver, servo motors also require a control to communicate back and forth […]
Find a Solution that Moves You with New Selection Tool
New online selection tool helps users find position feedback options from nine different brands As part of its ongoing “Customer First” initiative, HEIDENHAIN introduces the new multi-level online Encoder Selection Tool for automation. This new Encoder Selection Tool simplifies the encoder search process by considering various industries and applications, and then suggests brands with suitable […]
