HEIDENHAIN Now Offers CNC for Auxiliary Axes
April 13, 2017
Julian Renz, Product Specialist for Machine Tools, 847-884-4761
SCHAUMBURG, IL (April 2017) — HEIDENHAIN now offers the PNC 610 control system for auxiliary axes for modular expansion of the TNC hardware. The independently working PNC 610 enables machine tool builders to realize modular and scalable automation solutions for handling workpieces and tools in order to respond to the end users’ respective requirements in an optimum manner.
Auxiliary axes and principal axes can be interpolated with the PNC 610, and are usually used to perform movements on the periphery, such as in tool magazines or workpiece handling systems.
The PNC 610 can be connected to other machine system parts or to CNC controls via standard automation interfaces (TCP/IP, PROFIBUS-DP and PROFINET-IO). It is used to program axis movements in the integrated PLC. Established common PLC functions and HEIDENHAIN software tools from the TNC controls are also available for the PNC 610, for example, Teleservice or VNC can be utilized during setup via one of two Ethernet interfaces.
A recommendation for machine builders is to use the PNC 610 in combination with the UEC or UMC compact inverters as a very compact way for integration. If visualization is required, an ITC 755 industrial screen can be used with ASCII keyboard. Customized graphics can be written with the Python OEM option, for which 10MB of memory is provided.
Texas Instruments collaborates with HEIDENHAIN on first industrial drive control system-on-chip
In an exciting industry first, Texas Instruments (TI), with help from HEIDENHAIN, has developed a microcontroller (MCU) for the semiconductor industry—the C2000TM MCU.
Manufacturing Quality Starts with the Motor
Accuracy and surface quality are the goals of superior production processes. This is why machining companies invest a great deal of time and expense in tools, machine tools, controls with special functions and options, measuring technology, and, of course, employee skills.
HEIDENHAIN’s recent acquisition of AMO, has resulted in the Austrian specialty encoder company’s sales operations and products being coordinated at HEIDENHAIN CORPORATION in the U.S. for North America.  AMO encoder production and engineering will remain in Austria. AMO is well known for meeting the precision feedback requirements in applications where high resolution is needed, particularly […]
