ETEL’s New ZAO Force-Controlled Actuator
September 7, 2017
ZAOSchaumburg, Illinois (September 2017) – ETEL is pleased to announce its new ZAO Force-Controlled Actuator as entering its already broad range of advanced motion systems. Among other applications, ZAO is perfectly suited for semiconductor pick and place, die bonding and probing machines.
Coupled to ETEL’s AccurET controller, the ZAO Force-Controlled Actuator provides the user with a state-of-the-art solution to reduce machine cost of ownership while taking up the next force control challenge!
ZAO is a 30-mm travel actuator featuring a frictionless bearing arrangement and a light moving mass, ensuring very low and repeatable force application as well as low force overshoot at impact on a contact surface.
Built to take full advantage of ETEL’s sensorless Force-Control algorithm, ZAO allows simultaneously a very tight force control accuracy (0.2 N ±10%) and a very high dynamics capability (up to 20 g).
ZAO aims to address the new semiconductor back-end and electronics challenges driven by the new advanced packaging technologies and materials, specifically ensuring the integrity of fragile component or target substrates without compromising the machine throughput.
For more information on ETEL’s products and services, visit www.etelusa.com or contact Product Specialist Brian Zlotorzycki at HEIDENHAIN in North America at 847-755-5569.
Growth Leads to Management Appointments
Significant company growth and key initiatives lead to important management changes at HEIDENHAIN CORPORATION in North America.
HEIDENHAIN Acquires AMO
HEIDENHAIN recently acquired AMO, an Austrian specialty encoder company well known for meeting precision feedback requirements where high resolution is needed.
ETEL Broadens its Product Portfolio of Motion Solutions
CHARON2, the newest ETEL motion solutions addition, is a semiconductor-oriented stacked XY motion stage, backward compatible with existing modules and options.
